Programmatically Creating Image of a Tab
Is there a way to programmatically create an image file of specific tabs of a VI's front panel?  This would have to happen automatically, so a user will not be able to select the tab.
Thanks.
Forbes Black
Lapsed CLAD, LV 5 - LV 2023 (Yeah, I'm that old...)
(5,691 Views)
Hi diarmaede,
Set the tab to the page you need and read the tab image using a method node of the tab container...
This usually works with every control.
(5,690 Views)
Thanks.  How do I select the tab I want to image?  Can I specify the tab I want to image without having the front panel show that image?  I would like to select the tab to image without changing what a user sees on the front panel.
Forbes Black
(5,680 Views)
I think you will have to switch the page to show the one you want to create an image from to front...
When the user shouldn't see this you could create a 2nd VI off-screen or hidden with the same tab container on the front panel.
(5,652 Views)
Accepted by topic author diarmaede
If you defer panel updates, switch the tab, get the image, switch back, and then un-defer updates you don't need to use a hidden tab or other workaround to avoid a flicker:
(5,632 Views)
