Programmatically Editing Palettes
I can't get the palette editing functions to work.  No matter what I try, the palette never changes.  What's wrong with this:
(1,689 Views)
C:\temp\Untitled 1.vi suggests that VI is not saved. And while no error appears in such situation, palette file is not changed.
I saved a VI under this path and it is indeed added to Cluster palette - so the code is correct. I used LV2020, but I wouldn't expect it to make a difference.
(1,603 Views)
