Programmatically Open a Remote Front Panel with Panel Open Method
I am trying to open the front panel of the VI on my cRIO-9024 through a remote computer. Currently, I am able to run the VI with no problems with the RUN VI method; however, when I try to open the front panel, I receive "Error 1043 - This property or method is not supported in this version of LabVIEW" or the Front Panel is simply not visible. My cRIO is configured to allow TCP/IP protocol, The VI is visible, and I have made my project into a source distribution on my cRIO.
Any help or suggestions regarding this problem would be great. I am very new to LabVIEW.
I have attached a screenshot of my block diagram and project.
Jake
(3,582 Views)
Project Img
(3,580 Views)
If i understand your question correctly then this article should help you achive this.
http://digital.ni.com/public.nsf/allkb/AB6C6841486E84EA862576C8005A0C26?OpenDocument
(3,511 Views)
