Programmatically Open a Remote Panel from within an deployed RT target on a cRIO device
Hello All,
I'm currently working with two devices: a cRIO-9042 (used a main device) and a cRIO-9075 (used to verify the functionality and connections of the cRIO-9042). Currently, I can run the cRIO-9042 as a standalone device, and access the remote panel of the cRIO-9075 through the RT instance on the cRIO-9042 by going to Operate>Remote Panel and typing in the ip address, port and vi name on the cRIO-9075. Is there a way to do this programmatically, without having to navigate to this menu option and manually type in this info? I'm essentially trying to get process this down to only mouse clicks if possible, but being able to open the front panel of the cRIO-9075 RT target on the cRIO-9042 with a single user control is my end goal.
Message 1 of 1
(1,143 Views)
