Programmatically Swap Scales in Labview
Does anyone know if you can programmatically swap scales (y-scales) in Labview.  If so, how?
(4,212 Views)
Hi rmz,
there's a YScale.Swap property, which allows you to swap the min and max value of the scale.
When you want to swap the position of the Y axis (left or right side of the graph): this is only allowed at edit time. (I couldn't find a property for this.)
Possible solution workaround: create as many Y axes as you might need. Hide them when unused (using a property node). Assign the plots to the Y axis at runtime (using a property node).
(4,181 Views)
It'll take some experimenting, but you can do it like this:
Note: If you move the scale to a funky position, the chart can become confused.
(4,167 Views)
That is a good idea and probably is my best option.  Thanks.
(4,155 Views)
