Programmatically add input to bundle for charting
I am trying to programmatically add or remove an input from a bundle that is providing data to a chart. In this case, I would like to add Slide 3 to the chart programmatically. I was expecting to be able to somehow use a property node, but that doesn't seem to be available. Is there a way to change the number of bundle elements programmatically? Or another way to send data to a chart that can be changed programmatically?
(2,578 Views)
Accepted by topic author HobieTcat
Bundle all and replace the ones you want to hide with NaN, or just use the visibility checkbox.
(2,553 Views)
Note: You can also feed a 2D array of doubles to a Waveform Chart.
Each column is a different plot; rows correspond to x-values
(2,547 Views)
The two choices are not entirely equivalent, because the visibility property will hide the entire trace while the NaN can be used to create temporary "gaps", e.g. as follows.
(2,468 Views)
Thanks for the clarification on using NaN. I used the visibility checkbox and it worked the way I wanted, so I went with that as the Accepted Solution.
Knowing it was available was the biggest challenge for me.
(2,451 Views)
