Programmatically add multiple scales to graph
On the front panel, I can choose "duplicate scale" "delete scale" to add/remove multiple scales a Graph control.  Can I do this programmatically,i.e., use the VI to adjust the number of scales on the graph?  The purpose is to have variable number of plots on the same graph, each having a different scale.
Message 1 of 9
(9,102 Views)
I have come accross that same desire.
The way I did was create all the scales I ever needed ahead of time and then turn the visibility on/off programaticly.  You can also associate plots with scales programaticly.
Dan
Dan Shangraw, P.E.
Message 2 of 9
(9,095 Views)
I use this: Add the maximum number of needed scales per hand. You can swap sides to get a better look.
To switch on/off a scale use the property "Active Y Scale" to select the scale and "yscale.visible" to switch on/off.
I've written a small demo.  I hope it's usefull.
Message 3 of 9
(9,091 Views)
Hi Andreas_Fuerst I want to create duplicate scale for waveform chart for x axis. Is it possible to create ? the duplicate scale option from that menu list was not visible. I couldn't create duplicate scale. Please refer my attachments so that you can understand my problem.
Message 4 of 9
(6,022 Views)
I would say no.  Waveform charts are special in that you send data to them one point or a few points at a time and the X-axis is constantly moving.
You can create a duplicate scale for the X axis on Waveform Graphs and XY Graphs.
Message 5 of 9
(6,013 Views)
I came across the same issue: i want to programmatically create scales and activate them if needed. I see the visibility flag, but no way to automatically create them. Does somebody knows how to do it? or it is just not possible.
Adding it manually in advance is a solution, but not the best one.
Accessing the scale legend properties, should be possible like accessing plot legend. It is just an array....
Thanks!
Message 6 of 9
(4,256 Views)
Hi Marian,
It's the same state as it was 15 years ago: create the scales manually at edit time and then you can switch their visibility at runtime…
Message 7 of 9
(4,249 Views)
Hi GerdW,
Thanks a lot for the reply.
Too bad it was not improved until now....
Marian
Message 8 of 9
(4,241 Views)
It will be lots of work and little gain. Actually, 0 financial gain for NI...
It's the same for captions. You can only create them during edit time. Not even scripting can create a caption...
Message 9 of 9
(4,223 Views)
