Programmatically adjusting the font size of a string array
I can't find the correct property to programmatically adjust the font size of a string array.  For a string it's easy enough with a property node and the text.Fontsize property.  There must be a similar property for a string array, but I can't find it.  Can anyone help?
(4,738 Views)
Accepted by topic author ScottDobbins1
Grab the array element ref and type to more specific class (string) and then you can set the font size with a property node.
(4,730 Views)
Inertia:
Your solution was perfect, thanks.
Too bad that there is not a more direct way to access this property from the array property node...
(4,695 Views)
You can right-click the array element directly (not the array container!) and create a property node for it.
No need to jump through flaming hoops! 😄
(4,660 Views)
Altenbach:
Thanks sir.  Much appreciated.
(4,628 Views)
