Programmatically bind shared variable
I'm trying to bind a control to a shared variable, if I clic on properties=>Data Binding, everything is set up correctly, but I get a red flag. Then if I add a white space after the variable path then clic OK. everything is fine and working properly.
My problem is I have to bind hundreds of shared variables so I don't want to modify every single control properties...
Anyone has any clue on what's happening?
Rodéric L
Certified LabVIEW Architect
(3,390 Views)
I'm using LabVIEW 2010 SP1.
Rodéric L
(3,372 Views)
Anyone came across this?
Rodéric L
(3,349 Views)
Looking at some similar code that I had developed to set FP bindings, I included single quotes in the url, for example:
\\My Computer\IO\'PU.Heater_Power'
Maybe the space is satisfying the need for a delimiter of some sort?
(3,341 Views)
