Programmatically change Signal Input Range of each channel in a Task
I created a task in MAX which contains 2 channels (see pic attached) : Strength and Displacement. 'Strenght' is linked to a custom scale 'Strength_scale' and 'Displacement' is linked to a custom scale 'Displacement_scale'.
Due to calibration purpose, these scales may change.So the 'Signal Input Range' may vary with the scale change.
How to programmatically set these values independently for each channel in my task ? (like it can be done manually in MAX) Smiley Surprised
PS : I found a way to change both 'Signal Input Range' at the same time with same value. But my 2 scales are very different so I can't apply the same range for my 2 channels.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,253 Views)
The range is set with the DAQmx Create Channel function. You would simply have one for each channel - wiring the task out of one to the task in of the next.
(3,251 Views)
Thanks Dennis,
But I do not want to create channels as they are already specified in my task. I was hoping that I could do it with a property node upon my task and even store the min and max into MAX (like I do with the scales...cf. pic attached). The purpose here is to use MAX as a 'configuration database' and removing the need to recompile an application (or modify conf files).
(3,247 Views)
Maybe using 'Active Channels (if subset)' property over the task ? But I can't really find a way to use it. It generates an eeror each time I'm trying to set it... And if I don't specify it, AI.Max and AI.Min values (that I specify with the same property node) are applied to both channels in my task ... Smiley Indifferent
(3,241 Views)
