Programmatically change time/date format on a graph/chart
Is there a way to programmatically change the date format in a chart/graph from MM/DD/YYYY to DD/MM/YYYY?
(4,100 Views)
Just look at the menu Tools-> Options->Time and Date.
There you have several options to display your date, time etc.
Mike
"BShu" schrieb im Newsbeitrag
news:5065000000080000001F600000-1031838699000@exchange.ni.com...
(4,100 Views)
Thanks for the input. However, I'm looking for a way to be able to change the date format programmatically, transparent to the user (without having the user to change the format from the Tools menu).
(4,100 Views)
At this time, LV doesn't provide that level of control. Check back soon.
Greg McKaskle
(4,100 Views)
Nearly a decade later, checking in. Anyone know if LV has this capability now?
(3,549 Views)
yes
(3,547 Views)
