Programmatically changing string text color in an array of string indicators
I have an array of string indicators and I'm trying to format certain values different colors.  While I'm able to do this on a single string indicator I can't figure out how to handle the indexing of the array.  I have seen several examples with array of clusters but I am unable to translate to array of string indicators.
Any help would be appreciated.
ShotSimon
(4,985 Views)
Elements of an array can only differ in value. The properties are the same for all elements.
(4,966 Views)
Instead of a string array, where all elements have the same format, you should use a table, which basically behaves as a 2D string array. But there, you can adjust all text attributes (if you are using LV 8.x). See this thread
Chilly Charly    (aka CC)
(4,929 Views)
