Programmatically choose boolean to write in cluster
If only one button should be active, use a radiobutton control instead.
Message 11 of 15
(843 Views)
What about this?
(It's more 'appropriate' to use Array to cluster after the replace, but then you must know and set the cluster size)
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 15
(830 Views)
Accepted by topic author SydneyAVDE
@SydneyAVDE wrote:
As said before, today i will upload the code. Here it is. (saved in v20.0)
Functionality: only 1 button may be active, print last activated labelname into string.
I am sure this could be way more efficient.
Here's how it could look like using a radiobutton control (that's just a container for booleans where exactly one is true and the value is an enum with the label of the control. It can also be configured to allow "no selection" if needed).
Your blatant overuse of local variables blurs the distinction between control and indicator. Both strings should be indicators! Right?
Your keyboard keys are latch action, so they reset once read by the code (but the terminal must be inside its event structure!)
Message 13 of 15
(806 Views)
I had no idea you could modify the controls in a radiobutton control.
Message 14 of 15
(743 Views)
You can customize a great many things in LV if you look around. Here's some examples.
Awesome GUI Design Examples - LAVA Lounge - LAVA
Qestit Systems
Message 15 of 15
(733 Views)
