Programmatically control table text edit box
Hello, all!
Is there a way to programmatically control the text editing box in a table control, i.e., make it appear through means other than a mouse click on the table?
Thanks!
Slowpoke
(Using LabVIEW 8.5 on a PXI-8109 running Windows XP)
Slowpoke
CLAD (believe it or not!), using LabVIEW 8.5
They don't call me "Slowpoke" for nothin'!
(3,544 Views)
You can set the value of any single cell using Invoke Node => Set Cell Value.  Is this what you are looking for?
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,541 Views)
Hi, Matthew!  Thanks for your reply.
Not exactly; what I'd like to be able to do is make the table control "edit-ready" for the user, without the user having to perform a mouse click on the table or a particular cell.  I don't see any property or invoke nodes that would allow for that, but I might be missing something.  Setting Key Focus to "true" doesn't seem to do it, either.  (Not for a table control, anyway.)
Slowpoke
(3,519 Views)
Hello all,
I found a way to do what I want in an example VI at http://zone.ni.com/devzone/cda/epd/p/id/2317 , "Shifting Key Focus to a Table Cell Programmatically".  I guess I just wasn't searching with the right question.  Smiley Tongue  My thanks to Matthew and all who read my post.
Slowpoke
(3,514 Views)
