Programmatically debouncing Rising Edge boolean
Need a little help here. I need to debouncing the rising edge of an input digital signal, i can i do this?
Thank you very much.
Francesco.
(4,989 Views)
Accepted by topic author FM82
Hi Francesco,
so you get a rising edge signal and want to suppress any other edges for the next x milliseconds?
Use the BooleanCrossing (pt-by-pt) and the elapsed time function…
(4,974 Views)
Hi GerdW,
well... i don't catch you. Can you explain better? Smiley Embarassed
(4,967 Views)
Ok, these are vi i do not known until now. Thank you again!
(4,960 Views)
Hi Francesco,
use BooleanCrossing to detect the rising edge, use ElapsedTime to avoid bouncing:
(4,957 Views)
