Programmatically determine group membership under NI Security
I am trying to use NI Security provided with the LV DSC module (v8.2).  I would like to be able to programmatically determine the group membership of a given user.  Is there a way to do this?
--David Moerman
(7,433 Views)
David,
Unfortunately, there is no way to programmatically determine the group membership of a given user.  It just has not been implemented in the current set of Security VIs.  You can make a product suggestion for this so that R&D is aware of a need for such access for future releases.
http://digital.ni.com/applications/psc.nsf/default?OpenForm&temp1=&node=
Brian Coalson
Software Engineer
(7,108 Views)
David,
Also, here is a Knowledgebase article that covers the same topic:
Programmatically Determining which Security Groups a User Belongs to Using LabVIEW DSC
http://digital.ni.com/public.nsf/allkb/99A026B68D18B484862571DC006CD8EB?OpenDocument
Message Edited by Coal Man on 06-19-2007 09:12 AM
Brian Coalson
Software Engineer
(7,014 Views)
