Programmatically differentiate runtime from development in MacOSX
Anybody know a way for a VI to know if it is running in the development environment or the runtime environment?
It has been suggested to obtain the VI path, strip it back one, then use the File/Directory Info Vi to see if it is a directory or a file - the executable, but in MacOSX the "executable" is a directory!
I have looked at the VI properties, and I really cant't find anything that works.
(2,714 Views)
Try the property Application>>Kind. When you create a property node, it defaults to the current application, so just select the property.
___________________
Try to take over the world!
(2,707 Views)
You Rock! - exactly what I was looking for.
(2,690 Views)
