Programmatically editing VI Description
I am trying to programmatically edit the VI Description for a large set of VIs. Seems like it should be very easy, but it doesn't appear to work. I can read the VI Description text fine, but when I try to write to that property, nothing happens. The text does not get edited, and no error is reported. What am I doing wrong?
NI documentation says that the VI Description property can be programmatically set:
https://www.ni.com/docs/en-US/bundle/labview/page/creating-and-editing-vi-descriptions.html
Thank you for your help.
(3,832 Views)
Accepted by topic author Chris_12345
You need to save the VI after you update the description.
(3,828 Views)
