Programmatically find location of <userlib>
Hi all,
I'm using LV 2012. Is there a way to find the location of the <userlib> directory programmatically? I've seen the old stuff about the private Application->Resolve Symbolic Path method, but that is now deprecated. Is there an alternate solution?
Thank you,
Zola.
(2,949 Views)
You can use the vi lib path function and get the user lib path as shown below (Available as a function in OpenG)
(2,943 Views)
I believe you are correct regarding the function being deprecated, but this old VI from the LAVA forums loads and functions fine with my LV2012 32 bit installation.
http://lavag.org/topic/10549-resolving-symbolic-paths/#entry62790
I wouldn't include it in any distributed / compiled code but it could still be useful for writing private / throw-away type development tools...
(2,937 Views)
To P@Anand - Thank you. That works fine in the development environment. My problem is that I need to build an exe that knows where the LV installation is, and where the user.lib is inside of that. If you use this solution in a built program, it gives you the location of the user.lib in the build, not the location in the LV installation.
(2,929 Views)
To PhilipBrooks - Thank you. I only need this for an in house tool, so I might need to resort to that.
(2,924 Views)
