Programmatically get names of all cases in a case structure
Another trick for Enum's is how to transfer an array of strings to the Enum Control, for some reason LV 2015 and older, does not allow this on the same VI.
I found this trick using a simple ring - then replacing it with an Enum ring - and Voila!. LV copies the string list over from the Ring to the Enum.
Example VI attached.
Message 21 of 22
(807 Views)
Hi @jcarmody,
Could you please share the link to download the caseSelect plugin? I can not find on your signature..
Thank you..
Day@
Certified LabVIEW Associate Developer
Message 22 of 22
(789 Views)
