Programmatically load update enum
For my application I need to populate an enum from data base and then, let the user to choose from enum.
I have already found a code for populate an enum.
But now, How do I refresh the enum at the GUI so I will show the new values.
And Another question, How do I remove values from the enum?
Thanks!
Gil,
(1,762 Views)
Hi Gil,
You cannot change an enum while the VI is running, you can only change it in the IDE…
Simple solution: use a ring instead!
On those "How…" questions: there are property nodes where you can set/define the values of a ring…
(1,751 Views)
