Programmatically open a file and save it in a new directory
To start off, I'm relatively new to LabVIEW and did a couple searched about this and couldn't find anything pertaining to what I wanted.
Right now I have an event structure where I click a button and the file dialog comes up.  I then select a CAN database file.
After that is done I'd like to save the file to the program's directory and save the relative path to an array/spreadsheet/whatever (I haven't decided what would be the most appropriate yet).  Saving the relative path is the easy part.  After opening the file, I can't seem to find anything that will let me programmatically save it to another location.
Does anyone know how to do this?  Thank you for the help.
(2,547 Views)
File I/O >>  Advanced File functions as a Copy function.
(2,544 Views)
Thanks for the help.  Apparently, I didn't look aroun good enough or missed it.
(2,518 Views)
