Programmatically plot multiple annotations (points) on waveform graph
Using: LabVIEW 2011
I have a VI that displays a graph of the time-domain signal from an accelerometer, and a second graph that displays the FFT of that signal. I want a button that places an annotation (a point labelled with incremental values) at the peak of the FFT signal each time the button is pressed, and for each annotation to remain on the graph (The experimental rig is an unbalanced rotor with variable speed, so I want to plot the variation in peak as the rotor speed increases).
So far I have mananged to plot points with incremental values, but each time I click my 'plot' button* the previous annotation disappears (i.e. only one remains on the graph at a time), and I just can't figure out how to correct that. I have attached my VI, I feel I must be close but any further help would be appreciated.
* Which is currently 'latch until released' and has to be held down for one complete iteration of the VI. If I can get the rest working I will fix this later.
(4,516 Views)
Anyone?
(4,465 Views)
Accepted by topic author zaq
Hi zaq,
what happens when you use BuildArray instead of ReplaceArraySubset in the case structure?
I guess you want to append new annotations instead of replacing the one you have…
(4,453 Views)
Ah, I knew it must have been so simple but it's always the thing you don't think of! Thanks very much.
(4,403 Views)
