Programmatically reset BG colors in a MultiColumn List Box
Hi there,
I'm looking for an appropriate way of resetting the background colors of all cells within my listbox at once if possible. Using the Reset to Default invoke node reset the contents, but not the colors. I'd like to avoid setting all the cells to active cell sequentially and setting color afterwards.....
Any Ideas?
Cheers
Oli
(6,732 Views)
You can do it in up to 3 steps.  If you aren't showing your row headers, you can take off the last step.  Make sure you wire the error clusters so it does it in the right order.  Seems 8.5 removed this from the context help, but a -2 indicates all rows or columns, so the first steo selects every cell in the table and sets it to white.  -1 means the row or column headers.  So in the second step, it selects the column header for all columns.  The third step selects the row header for all rows.  Both set the color to Classic Object.
Message Edited by Matthew Kelton on 02-19-2008 09:56 AM
(6,724 Views)
Hi Matthew,
worked perfectly! Smiley Happy
Thank you very much!
Oli
(6,697 Views)
