Programmatically reset or control scrollbar index on pane
I'm trying to programmatically turn on and off the scrollbar within a single pane on a multi-pane front panel, when I switch it off I also want the scroll position to return to the initial start position (zero position). I am able to turn the visibility of the scrollbar on and off using the pane property node but I can't see a way to control it's scroll position/index. Is it possible?
(2,506 Views)
Accepted by topic author Rambo_No.5
(2,498 Views)
Well that was nice and easy, thank you!
(2,487 Views)
You can also statically link a property node to a pane:
(2,409 Views)
