Programmatically resizing VI within Event Structure does not repaint
Resizing a VI while inside an Event Structure does not repaint the VI. I tried many things to get it to work but none fixed the issue. I am reporting this as a potential bug/incorrect behavior.
There is a short thread on the forum that discuses the problem titled "Programmatically resizing Front Panel does not repaint".
Naveen.
(2,935 Views)
Naveen,
Thank you for letting other customers know of this issue. NI is aware of the problem and is working to address this and other issues we have seen with the event structure.
You should be able to work around this problem by unchecking "Lock Panel Until Handler Completes" after right clicking on the event structure.
Matt Kisler
(2,935 Views)
