Programmatically set system time in labview RT
I know how to set the system time through the system utilities vis (using localhost as the target system). How can I apply that system time to the PXIe Controller hardware clock?  The set system time vi does not update the hardware clock it seems when a UTC time is provided without applying a time zone (if that makes any difference).
thanks,
Xl600
(3,483 Views)
xl600,
You can synchronize your RT controller to your host by referencing it as a time server or using NTP.
Some of these knowledge base articles may help you:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YILpCAO&l=en-US
http://digital.ni.com/public.nsf/allkb/DC20E31E0067D76486257544005A1376
Aaron L.
(3,407 Views)
