Programmatically setting cursor line styles
I'm trying to show door openings and closings on a graph using cursors. I'd like to have a dashed line for an opening and a solid line for the closing of the same color. I can draw the cursors of the same color easily enough by creating an array using the cursor properties (I could also use different colors for each, but that is less ideal). I don't see where line style or line width are options in those properties however. I did find this old post on the topic;
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Line-Width-and-Line-Style-to-Cursor-List-Property...
In the 3rd post, he says it can be done but I'm too dense to understand what he is saying need to be done to make it work. Could anyone show me an example of what he means or explain another way to do this?
Thanks in advance.
(4,573 Views)
Accepted by topic author SteveC_43
Hi Steve,
Jack suggested to first set the ActiveCursor, then set it's line style and width:
Repeat this for each cursor you want to manipulate.
(Sorry, I'm using German LabVIEW.)
(4,565 Views)
Ah. I'm an idiot. I wasn't thinking of the ActiveCursor as the graph property. I'll play around with that. For now, I'll mark this as solved.
Thanks as always GerdW!
(4,544 Views)
