Programmatically turn folder of png files into gif
Hi, isf there is a way to turn a folder of png files (labelled 0-x in order) into a gif within labview?
I have searched around the topic and found that there are websites that can do this. I also came across recommendations for external programs that can do it (with a command sent to them through LabVIEW).
I'd prefer to be able to do it internally on LabVIEW - any ideas?
Thanks!
(4,202 Views)
Hello cna,
you can try the example in the last post
Pixelmap or image from 3D Control?
also interesting
How Do I Create an Animation Using a Picture Ring Control in LabVIEW?
best regards
Alexander
(4,191 Views)
Hi , thanks for the reply.
In the first link I downloaded the exmaple llb but can't quite figure out what  is going on?
The second doesn't seem like it would suit my needs as it has a lot of labour.
To elaborate: I have my code getting and saving the image of a graph (iterating through files) to a folder. Currently I can then upload these files to a site and get an animated gif out of them.
Cheers
(4,144 Views)
Hello cna,
the Util.Pic.GIF.Write.vi is the interesting VI here you can add the Option to load the png files
best regards
Alexander
(4,134 Views)
Hi Duffy, thanks for pointing that out! I'll give it a go.
(4,126 Views)
Hmm,
I've got the library loaded in my project. But when I pass an array of image data to the main write VI, it gives an error that the first file should have a colour table or something along those lines?
Have you ever used the VI's and got a similar error?
I'll keep fiddling around in the meantime
(4,116 Views)
Hello cna,
i have then tried this example which works
GIF Animations in LabVIEW
also in vi,lib:
vi.lib\picture\gif.llb\Write GIF File.vi
but it doesn't support animation.
best regards
Alexander
(4,092 Views)
