Programming Atmel 8051 in LABVIEW
HI
My application requires to programme atmel microcontroller at89s8252 which has inbuilt RS232, spi interface for the data acquisition from wind and tilt sensor.
How can i programme Microcontrollers in genral in labview?
Any help will greatly be appricieated.
Jay Ravi
e-mail:raviraj.jr@gmail.com
Message 1 of 9
(11,572 Views)
Accepted by topic author Jay Ravii
1. If your mcu has a bootloader, you can send the data through UART and program the chip.
2. The program that you currently use to program the chip, probably have dlls that you can use (that seems the difficult way for me)
3. AVR Studio (for AVR)  has support for command line programming. Maydbe yours, has something similar. (this is the easy way, i think).
I tried something similar for a few days, but did not had the time to proceed.
Keep us informed, if you manage to accomplise your task.
Message 2 of 9
(11,564 Views)
How you did that ?
Message 3 of 9
(11,513 Views)
I'm very sorry,i'm new to this group and clicked something else and i appeard as if its solved, by the way i'm still working on diff methods to programme MCU usying labiew.
I'll revert back soon,
i'm sorry..
Message 4 of 9
(11,477 Views)
HI
Jay Ravi
Message 5 of 9
(11,476 Views)
Hi ,
You can programme 32 bit microcontrollers using microprocessor SDK module of LabVIEW . Please refer to the following link for more information .
http://sine.ni.com/nips/cds/view/p/lang/en/nid/201953
PS: WE support programming of LabVIEW Arm Microcontrollers also
Some more information on programming microcontrollers in LabVIEW can be found in following link -
http://zone.ni.com/devzone/cda/tut/p/id/7066
Please get back to us if u need some other info -
Pranchal Srivastava,
NI India
Message 6 of 9
(11,414 Views)
Thanks for your answer, any licensed user of labview will have this embedded module installed or need to buy seperately once again,I got new dvd's of 8.6 couple of days back, is this feature exists in that.
I'm not keen on ARM right now, simple 8051 is all i require for my application, is it possible to programme the same in Embeddd module.
Pls help me in this regard.
Message 7 of 9
(11,395 Views)
Hi ,
No you dont get the SDK module with the LABVIEW Evaluation DVD . The best way to program the 8051 will be as pointed out by a user before is
using serial communication between 8051's UART and the computer serial port. It is fairly straightforward to implement a simple ASCII command set. You won't find a driver as such, since your application and command set will be unique. In LabVIEW you send the ASCII commmand to the serial port and read the expected answer.
LabVIEW mainly supports 32 bit microprocessors with SCK modules . For 8 bit this is a good way . Hope that helps !!
Thanks and Regards ,
AE ,
NI India
Message 8 of 9
(11,359 Views)
 I have almost the same problem as Jay,
I downloaded the last version of labview, in evaluation mode for the moment, but really interessted ! I have the licence for Keil,
The download is just here :
https://lumen.ni.com/nicif/us/ekitlvembdarm/content.xhtml
but I have to program an Atmel AT91SAM7A3 ARM7 32bits, and I read a lot of page in the NI web site like :
http://zone.ni.com/devzone/cda/tut/p/id/7152#toc2
http://zone.ni.com/devzone/cda/tut/p/id/6994
but the version of labview change and I don't succeded to do that .
Someone can help me ?
Thanks for you help !
Yannick
uC : Atmel ARM7 AT91SAM7A3
LV embedded module for ARM 2009, eval mode
KEIL 3.85 licenced
OS : windows 7
Message 9 of 9
(10,091 Views)
