Programming LabVIEW
I like to cahnge programmatic the Text color on a labeled square button Object.
under Labview 4.1
It is possible ?
Regards
(3,095 Views)
Shaul,
To change the color programically, go the the item (in diagram view), right
click on it, and select create attribute node, once you have the node,
change the selected property to text color and wire in the color you want to
change it into. You can show and hide this way, also to get a similar
effect.
Mark Eckdahl
SLO Consulting
meckdahl@yahoo.com
"Shaul Dotan" wrote in message
news:388c2e1e@newsgroups.ni.com...
Object.
> under Labview 4.1
> It is possible ?
> Regards
Mark Eckdahl - Software Manager at Blue Max Systems
LabVIEW developer for 20 years
(3,095 Views)
