Programming NI-9148 when not connected
I am attempting to get started programming the NI-9148, but don't have the 9148 available at the moment. I was hoping to be able to create a target and do all my programming for the NI-9148 offline then compile and move the fpga program over to the device once I get my mitts on it. It looks like I have the FPGA module installed (NI Max >> software >> LabVIEW 2018 SP1 >> FPGA). and I attempted to follow the setup guide for NI-RIO ehternet setups (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGx7CAG&l=en-US) from here I go to the section.
 Required Software for the NI 9148
  1. LabVIEW 32-bit 2010 to 2019 SP1
  2. LabVIEW FPGA Module* 32-bit 2010 to 2019
  3. NI-RIO 3.5.1 or 19.6
Note: Software should be installed in the order listed.
*LabVIEW FPGA is only necessary if you plan to write your own FPGA program for the FPGA target in the NI 9148. Use of the Scan Mode Interface is possible without the LabVIEW FPGA Module.
After the installation I was hoping to create a new project>> add new target>> select NI-9149... Except there are no selections for Ethernet RIO available?
I have no clue what drivers I need to download for me to begin developing on this target?
Message 1 of 1
(1,295 Views)
