Programming Total Flow
Alright, well I have it working where it will give me the correct volume when the draw starts and as the draw continues I get accurate measurements. When the valve is closed the draw stops and so does my running total until I open the valve back up. I ended up just using the cycle time and a simple feedback node to accomplish the job (as seen in "Total Flow 3" attached).
My current issue is getting the "Total Volume" to reset to 0.0 when the valve is closed, so that when I open it back up it starts the running total on a clean slate. I know a few people have suggested ways about doing this, but I am having a hard time figuring out a way to make it work. If possible an example would be incredible, but if not advice is always appreciated. Thank You!
Message 11 of 15
(1,710 Views)
In the false case of your upper left case structure, wire 0 to the total volume output.
Message 12 of 15
(1,682 Views)
Thank You! I don't know why I made that so much harder than it actually was. The program is finished and runs smoothly! I incorporated an extra shift register to record total volume flow throughout the entire test as well as the running total that resets after each draw. Thank you all for your helpful advice, now I just need to decide which reply I should mark as the solution to my original question.
Message 13 of 15
(1,647 Views)
If anyone following this post is interested in assisting me with the next big step in my program, I have ran into issues once more and started a new topic. You can find the post here: Relay Control via Time & Total Flow
Thanks again for everyone's help!
Message 14 of 15
(1,588 Views)
Hint: You can mark more than one post as a solution!  😄
Bill
CLD
(Mid-Level minion.)
Message 15 of 15
(1,581 Views)
