Programming for Keysight N9020A using LabView
I want to store and process the data measured by Keysight N9020A on a PC using LabView. I would like to output the obtained data to a waveform diagram or to a csv file, etc. I programmed like the first image, but when I run it, I get an error like the second image. However, it seems that communication is possible, and I can change the frequency band, for example.
Would someone tell me the solution?
(1,330 Views)
Run the vi with highlight execution an then click on Sigle Stepping execution, this way Labview will execute the VI step by step and you will be able to see where the error occurs. Without know much about the equipment, I would guess that the instrument does not recognize the trace name "kaneda".
(1,256 Views)
