Progress bar
I cannot open the VI. Your LV version is newer than mine.
Message 11 of 21
(2,560 Views)
What version do you have?
Certified LabVIEW Architect
Message 12 of 21
(2,558 Views)
Mine is version 18.0.1
Message 13 of 21
(2,552 Views)
Message 14 of 21
(2,551 Views)
I use this a lot,
Message 15 of 21
(2,492 Views)
@altenbach wrote:
... or in a popup (subVI could show its front panel with only a progress bar visible).?
Here's a quick example for that
(Intentionally kept simple. Note that the process can be interrupted by e.g. pressing cancel or the <esc> key. Modify as needed)
Message 16 of 21
(2,475 Views)
What should i do if i have so many for loops in parallel and i want to know about the progress of all of it as a whole ?
Message 17 of 21
(2,431 Views)
Idea:
Each for loop has a current iteration and a max (N). Add all N to get the max for the progress bar and let each for loop send its updated iteration to Main, which adds the iteration-values and sets it to the progress bar.
Message 18 of 21
(2,426 Views)
Again, channel wires to the rescue. Using the accumulator tag and one counter for N and one for i, there is almost no code.
Message 19 of 21
(2,422 Views)
I have many for loops in my SubVis and if i use channel methods then it is going to be very messy. Is there another way around ?
Message 20 of 21
(2,372 Views)
