Project Explorer: organizing Items versus Files
Sadly, I don't know the first thing about using Project Explorer. Why do there seem to be two parallel systems for organizing my work?
Should I focus on logically organizing all the parts of a project as Items? or as Files?
Or should I have two different approaches to organization, using one with Items and the other with Files?
Or if I organize one of these, will Project Explorer automatically organize the other to match that? For example do I organize Items and then let Project Explorer create or manage autopopulating folders to mimic it?
I've read things like "Best Practices for Managing NI LabVIEW Applications Using the Project Explorer" but I keep getting lost in details like dealing with conflicts, and am not seeing the forest for the trees.
I'm either working by myself or, occasionally, with one other person. We're not using source control. I frequently create copies of everything and archive them outside LV's search scope so I can go back to older versions if needed. What I know I want to do with Project Explorer includes creating executables and things I can distribute (which so far I've done on tiny projects with no real organization, having every file in the same folder), and also housekeeping chores like removing all the obsolete vis that no longer have any callers. I hear people praise Project Explorer so no doubt if I got the point of it I'd get much more out of using it.
So, if any Project Explorer fans could point me in the right direction, I'm all ears and would be most appreciative! Thanks!
Message 1 of 32
(7,269 Views)
My advise is to never ever (even on Halloween) use Auto-Populating folders. (see this discussion, or this one).
What I normally do on disk, is one folder per function/library/toolset/module
In the project I manage all the files, on disk I dump everything in those sub-folders.
The project is your friend my friend.
Ton
My LabVIEW Ideas
Message 2 of 32
(7,261 Views)
The Project Explorer is indeed your friend, but it can sometimes be like a friend who doesn't know when to leave. Smiley Very Happy One of my main pet peeves about the Project Explorer is that it doesn't synchronize with the file system. I know that some see this as a "plus" (and I don't want to start a debate on this), but I don't, so I sympathize with cebailey. I'm used to the Visual Studio Solution Explorer where if I create a new folder in the Solution Explorer to organize my classes, then by golly a folder gets created on disk. Gee, what a concept!
Message 3 of 32
(7,240 Views)
I want to make sure I understand what you are saying:
OK, this I understand!
You mean when you organize everything in your project, you are using Project Explorer and looking at the "Files" view? You are not doing anything with "Items"?
You mean the disk folders have many many items in them and the logical way you think of the components of your project is represented elsewhere, not in disk folder organization? Or the subfolder organization is simple, maybe one layer deep, and your logical project organization is elsewhere, like in the "Items" view?
 Sorry if I am being slow. I've never been primarily a programmer or worked in a programming shop, but still hope to learn a basically sound if simple approach to this. I hope that if you put "Friends don't let friends code without LabVIEW Project Explorer" in your signature, you're more enthusiastic than most about promoting it.
Message 4 of 32
(7,232 Views)
Smercurio, how do you do your organizing, then? Do you organize in the "Items" view of Project Explorer, or the "Files" view, or both?
Can you just organize in the Items view, in which you are also seeing things that aren't files, and with the Files view you just put everything into one big folder? It sounds like it's a bad idea to have multiple vis with the same name, so assuming we don't do that, you could put all your files into one folder, right?
Is there going to be an opportunity somewhere to cull out all the vis that have no callers? So far, that is the only organizational activity I've wished for.
Message 5 of 32
(7,229 Views)
Yes I only use the items view. I have never seriously looked at the files view.
Looking for all files without callers will be programmatic task. A project has methods to return all the files within the project.
Here is a little discussion on possible improvements for the project explorer.
Ton
Message Edited by TonP on 01-13-2009 05:35 PM
My LabVIEW Ideas
Message 6 of 32
(7,224 Views)
I'm using 8.2 - I don't have this option. However, the 8.2 version is basically the "Files" view. I would most likely use this view due to the number of VIs that I have and the way the files are organized. The "auto-populating" would be the closest that would match what happens with the Visual Studio Solution Explorer, but then, the consensus seems to be to not use "auto-populating". So much for that.
Message 7 of 32
(7,210 Views)
Accepted by topic author cebailey
It's up to you to find the best method for using the Project Explorer. What I have found to be the most helpful for basic information is the following:
1. I save the VIs I am working with in one local folder on disk
2. In Project Explorer, I usually stick to the Items view
3. I add my high level VIs (Right-Click My Computer >> Add >> File...) and the Project Explorer will automatically populate the Dependencies with my subVIs
This gives me a small window (Project Explorer) that holds an organized list of my high level VIs, and I can access any subVIs in the dependencies folder.  I might create virtual folders (Right-Click My Computer >> New >> Virtual Folder) in order to categorize and organize my VIs further.
This leaves me with all my VIs saved in one location on disk, and one central access point from which I can manipulate them.
I usually only use the File view in order to find the physical location of my files, but since I saved them all to the same folder, it's usually not a big consideration.
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Message 8 of 32
(7,180 Views)
Good. What did they picture us doing with it? "What's it for?"
I guess there are enough different ways of using it that this is a hard question to just answer.
Your 1. 2. 3. is a very useful starting point, thanks! I am doing that and watching what turns out useful.
Message 9 of 32
(7,170 Views)
The Project Explorer is used for many different applications. Mainly, it is a central place where you can keep and manage all of the parts to a large project, including VIs, Global Variables, custom menus, custom controls, etc. In addition, it is where you define what VIs and executables are loaded onto a real-time target, if you are putting together a deterministic real-time system.
 So it ends up being a pretty useful tool once you get used to it.
Message Edited by Will S. on 01-14-2009 01:34 PM
Will
LabVIEW Champion
choose-mc.com
Message 10 of 32
(7,166 Views)
