Project Exporer File List Options
Is there a way to list files by order added to the project? file created? file modified? type? size? etc?
(*) This question is just probing the water before I go to the Idea Exchange forum unless I have missed something obvious.
(3,303 Views)
Hi X,
This help page explains how you can sort by name, type, and path.
I don't believe that LabVIEW or the Project file even stores the information of when a file was added to the project.
I hope this helps,
(3,281 Views)
OK, thanks. I guess I did not miss "the obvious" in the sense that I now remember having used this to sort some of my folders alphabetically but just could not figure out where to find it. Now I know. I think it would be much easier (and more standard?) to have different columns (number,order and type user-selectable) with the usual behavior: clicking the column header sorts the selected item(s) one way, clicking it again sorts it the opposite way.
(3,278 Views)
