Project not transferring from one FPGA target to another
I tried this in Windows 7 and Windows 8 with a patched LV2015 install.
This is what the project looks like:
The reason I ask for the 2010 version is because I think some things have been altered in the conversion making it very difficult to know what goes where.  Going to the older version may increase our chances.
Could you provide screenshots of the older version with project expanded so we see what goes where will help (like my image above)?
Also, the fpga.vi.vi has this (DBL) which means something was altered to make this wire into a DBL (this would not have been like that on a functional FPGA VI (even in an older version)
Did this program ever run in 2010?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 11 of 13
(551 Views)
I'm attaching the Project version from LV2010 and a screenshot of the Project Explorer. The Project did run (and is currently running) on the old computer (LV2010, Windows XP).
I'm also currently upgrading from LV 2015 to LV 2016 on the new computer, and I'll try cloning and running the Project there as well.
Thank you all for your responses!
Message 12 of 13
(542 Views)
Looks good so far.  Everything seems to be intact (had to repoint things).
The yellow triangle exclamation mark is the only issue I see for now which I think should be ok on your machine cause you probably have the right drivers.
fpga.vi.vi is still broken but maybe it will not be on your computer:
ALE Consultants
Message 13 of 13
(536 Views)
