Projectile motion
I am trying to create the simulation of a projectile motion in Labview. Here is vi I am using.  The formula for y I am using is this : y = (tan θ0)x – gx2/2(v0cosθ0)2
I am using case structure to allow negative values of angles to exist too. I read here in community that for negative angles the formula needs to have + instead of - .  Parabola comes out okay for almost every angle, however for 30 degree it comes out like this:
I suspect it is because x*tan(alpha) is smaller than the second part of the formula, therefore negative values come out. 60 degrees and 45 are okay. How can I get a simulation for 30 degrees?
Message 1 of 9
(6,587 Views)
First of all, note that the trigonometric functions want radians (full circle is 2pi, not 360), so a value of "30" corresponds to quite a few turns. Make sure to convert it first!
It would be so much simpler to calculate the evolution of  x and y independently (each initialized according to angle and magnitude). Now the speed in x is constant and the speed in y is a simple acceleration. (you can even add a air friction term later if needed). No tan needed.
Even easier, do things using complex numbers!
Message 2 of 9
(6,584 Views)
It seems ironic to me that "simpler" is "complex".
Bill
CLD
(Mid-Level minion.)
Message 3 of 9
(6,559 Views)
Bill,
     "Complex" just isn't "Real", it is also "Imaginary" (at the same time ...).  Still, it does make for a "simpler" (in some mathematical sense) mapping of a 2-Dimensional space than do "real" numbers (which take Two to Tango ...).
Bob Schor
Message 4 of 9
(6,555 Views)
I just read my previous response to my wife, and told her it had 4 Kudos.  She said I should say "If you like this response, don't thank me, thank i ".  But that would just be silly ...
Bob Schor
Message 5 of 9
(6,426 Views)
4 kudos is just under-rated, these puns are worth being made historic so that someone in the future can quote it as "by Bob Schor"
Santhosh
Soliton Technologies
Message 6 of 9
(6,420 Views)
that was fun
Message 7 of 9
(6,370 Views)
@Bob_Schor wrote:
Bill,
Bob Schor
There are many cases where using complex numbers simplifies the math.
In circuit analysis, Ohm's law doesn't work for AC, if you use real numbers.  But if you use complex voltage, complex current, and complex impedance, then Ohm's law does work and you can do circuit analysis without trig.
Message 8 of 9
(6,351 Views)
Here's my quick attempt using complex only (no explicit trigonometry!). I am sure it can be polished up a bit. 😄
Message 9 of 9
(6,309 Views)
