Prompt User Input - Limit
Hello
I am using the "Prompt user input" VI to enter a text in the "Text entry box" field. Nevertheless, I need to limit the number of letters of this entry. Someone did this before?
Dan07
Message Edited by dan07 on 08-08-2009 04:27 AM
(3,866 Views)
Yes. It has also been asked lots and lots of times. Did you try a search?
E.g.:
http://forums.ni.com/ni/board/message?board.id=170&message.id=378488&query.id=1587886
(3,847 Views)
Accepted by topic author dan07
P.S. You will, of course, need to create your own version of that Express VI. Just convert the Express VI into a regular VI (right-click on it and select "Open Front Panel". This will give you a copy of the VI that you can modify.
(3,843 Views)
Thanks for the help. The code is working very well now!
(3,756 Views)
