Prompt User (default values)
I'm using labview 7.0.  I want to display a dialog box that asks for three number inputs.  I have this setup using the "prompt user for input" function.  It works fine, but the default values are 0 for all three numbers.  Is there any way to set all the default values to 1?
(3,425 Views)
On the BD and right click on the Prompt User express vi and select Open Front Panel.  Confirm the conversion.  Set the new untitleld vi's Indicator's Default values to whatever you need and save the vi.
2006 Ultimate LabVIEW G-eek.
(3,413 Views)
