10-17-2011 09:04 AM
Hi All
I have a program which I made into an exe but when the program closes the front panel to exit, it will prompt to "Save changes".
Some items on the panel are repositioned when it is running and I do not need to save the changes. But I dont understand why it will ask this even if the program is turned into an EXE
Any ideas on how to stop the "save changes" prompt from comming up?
10-17-2011 09:44 AM
I haven't tried this but try adding a revert vi method in your clean-up/shut down code since you don't want to save the changes anyway- tossing em out seams sensible.
Whoops revert method won't work(not available in run-time not writable while running)
Hmmmm....
10-17-2011 09:59 AM
try adding "readOnlyLock=TRUE" withoiut quotes in the executables .ini file and make the vi read only
