Proper Template for Data Acquisition and Automated Testing
Hi, I'm planning to develop a VI to handle end-of-line testing for a product. It needs to be reliable, robust, and user-friendly so this is pretty new territory from just designing a straight automated tester or a straight data acquisition VI. My VI needs to:
- Read/Send periodic CAN data at 100Hz
- Read multiple ADC channels
- Perform a test routine involving CAN data and the ADC data
- Write test results to a data-base
- Display values to front panel and take input from front panel
I did something similar a few months ago for gathering data for a model but it had many issues. I used several timed while loops but ran into data dependency issues and over-runs. It worked okay for what I needed it for, but this next iteration needs to be much better. A queued messasge model seems like it would have prevented those issues. There's also the producer/consumer model which also seems like it would work, and then the actor framework which seems to be the most robust but may require some learning. I just need to pick one and stick with it.
So, which model do you all think would be best for my application? Producer/consumer, queued messages, or actor framework? Something else?
(2,891 Views)
An application doesn't usually conform to only a single isolated design pattern.  For example, in a producer/consumer in LabVIEW, the consumer is often a queued message handler.
Is this application going to be all on one target?
(2,884 Views)
It is. The application will run on an automated testing station and make use of the various peripherals on it, like the CAN controller, the ADCs, and a few other instruments.
(2,879 Views)
