Properties and delete tabs are greyed out in MAX.
Using NI 9263 and 9205 in 9174 chasis. Any suggestions?
(2,848 Views)
You may need to show a screenshot to help us.
If you receintly upgraded to MAX 4.7 some of the display areas did change.  Are you looking in the DAQ Devices section or in the chassis?
(2,842 Views)
Thanks. I looked at the security settings in my NI folder and I have allowed full access so that shouldn't be an issue.
(2,835 Views)
Dear ScottLock,
This is actually not a problem. It is expected to be that way. You do not have the delete option because your are using a real device as oposed to a simulated one. And you are not supposed to change the properties of your cDAQ modules individually. So that's why the properties are greyed out.
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(2,782 Views)
