This is a strange issue specific to a particular computer.  When I open a large complex application (in LabVIEW 2017 SP2 64-bit; "Total" memory usage: ~5MB), right-click on a control and select "Properties", the pop-up window does not open.  If I open a small sub-VI by itself outside of the main VI, I can get the pop-up window.  I can port the entire application to a different computer with the same installation of LabVIEW and the pop-up works fine.  I've tried repairing the installation of LabVIEW on this computer, and am afraid my next step may be to uninstall and reinstall.  Is this a memory issue?  Is there something else I should try?
