Property Node? Output to visual boolean array loop?
Hey guys! I'm relatively new to labview and am currently making a "pong" game for a project. SO far what I have working relatively the way i'd like it too
* User inputs a shot strength value that is compared for equivalency to a randomly generated #
* if the two values are equivalent, the "made shot" bool indicator will activate
what I need a little guidance on is outputting to a boolean array of indicators that value if they are matching.
what I have currently in the VI is me attempting to initialize a boolean array 0-9 which will fill at the index of the matching values.(AKA if user selects 7, number generator hits 7, boolean array indicator 6 should light up on the front panel and remain lit.)
Thus far i've been able to get some of the boolean array indicators to light but only one at a time, so I believe my problem lies within my use of either the feedback node or my lack of use of a "property node" which I do not understand really at all for this application.
Any insight greatly appreciated!!
sebastian
(2,679 Views)
Here is a snippet of my vi in case the above file doesn't work.
(2,677 Views)
Look into Event structures, and state machines.
  1. Your loop is spinning infinitely fast - not good
  2. Your boolean array is not updated until after the loop exits - not good?
  3. Change your number to integers, better for comparison.
  4. Learn to use Event structures.
Attached is a 2014 LabVIEW version that may help you get started or really confuse you, I put it together pretty fast.
mcduff
(2,649 Views)
Thanks a lot! Definitely learned a great deal.
(2,627 Views)
