Property Node Write Access to Second Array Dimension
I have a 2D Array as a control on the front panel. I want write access the second array dimension
using a Property Node > IndexVal, but it only accesses the first dimension index. Is there a way
to index the second dimension?
(2,755 Views)
The IndexVal property node is an array, the second element of that array will access the second dimension.
Paulo
(2,751 Views)
Yup, that is the method to change that property 😉
Many Thanks,
james
(2,740 Views)
