Property Node for a control within a cluster
Sorry, but I do not get the Data Entry limits  as a Property Node !!! in LV 8.2 FDS.
Could you send me an example ?
Regards
Message 11 of 15
(1,794 Views)
Did you try to right click the numeric control on the front panel within the cluster to create your property node?
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 12 of 15
(1,786 Views)
Message Edited by JeffOverton on 09-25-2008 07:30 AM
Message 13 of 15
(1,773 Views)
And what happend, if you have a Cluster inside a cluster that is inside a cluster that is inside a tab, how can you get all references of controls in the front panel, including controls inside other controls...
Roberto Villarreal Montemayor
Certified LabVIEW Developer
LabVIEW Student Ambassador
Monterrey, Nuevo Leon, Mexico
Message 14 of 15
(1,330 Views)
roberto,
This is a very old thread.
You can use Traverse for GObjects.vi (Application Control >> VI Scripting palette) to get references recursively.
Lynn
I was an exchange student at ITESM in Monterrey many years ago.
Message 15 of 15
(1,324 Views)
