Property Node for graph scale at Tab Control read.
Hello!
I try to read out the my Zscale from the graph which work with autoscale. That graph locate at one of pages of TabControl.
If graph page do not open to show, the property node return last shown value.
So if I locate at graph page, everything work fine, but if go to other. The Zscale stop change.
Simple example attached.
How to solve that issue?
Thanks!
(3,929 Views)
Accepted by topic author BrainBurn
P.S. I do see stupid solution - tab change every time before read out. May be you knew better way?
(3,908 Views)
How about have a second version of the graph that you keep off a tab control and offscreen and you get the scale values off of that one?
(3,872 Views)
I time to time turn off auto scale( that actually reason why I need to save it. To plot the data the same way at post processing).
I probably could catch up that with event handler, but that looks to complicated.
But thanks for nice idea!
(3,860 Views)
I would have thought the "Force Redraw" invoke node would have been a suitable option to make this silently update while it is hidden on another tab, but it seems to make the graph show through on top of the selected (no graph) tab.
Might be the intended behaviour, since it literally forced the redraw, but seems a bit like a bug to me. (LV2015 64bit).
0xDEAD
(3,858 Views)
I looking for something like that=) Sad that it do not workout. Thanks!
I also try to use Force Redraw with visible, False. Turns out that if plot is invisible, you not able to got scale too.
(3,850 Views)
Yes, I also attempted that and had the same result.
It seems the Y scale max is only updated at the point of redraw 😞 .. which I guess makes sense.
0xDEAD
(3,836 Views)
