Property Node "WatchPlots" of "Mixed Signal Graph"
When assigning different plots in the array "Write Watchplots" like for example plot 2 and 4, i often get an error or the Labview 8 crashes.
Do you have a solution for this error.
Thank you in advance for your help,
Claude
(2,771 Views)
Thank you for letting us know about this issue. I was able to re-produce the error and generated an error log file which I am turning into a corrective action. We currently do not have a work around for the situation, but if I become aware of one I will be sure to post it on this forum. Thanks again for helping us become aware of the situation. Thanks.
Tyler H.
(2,756 Views)
